MStep
I've presented some of the "anomalies" and "niggles" in other threads here regarding the Icom R8600. As I explore the receiver functions in greater detail, perhaps I (along with others here who would like to contribute) can offer some Tips and Tricks that may help others utilize the full potential of the receiver.
On the the topics often mentioned in some of the YouTube videos is the somewhat quirky process of getting a frequency up and running via the display. In this thread, I will start with one topic that should be somewhat helpful to R8600 users.
Mike's Tip / Trick# 1: Short Press/Long Press
Here is one of the items that can help listeners do a quick evaluation of vast swaths of frequencies with minimal effort.
The frequency display is divided into three sections, which we will call "megahertz", "kilohertz", and "hertz". For example, a typical frequency will read out, for example, as 453.123.500. The "453" represents the megahertz, the "123" represents the kilohertz, and the "500" is the hertz.
We are concerned here primarily with a "long" press on the display on the megahertz area. A short press in that segment of the display brings up the 'F-INP" (Frequency Input) screen. But a LONG press on that segment does something very interesting--- it places a small cursor over the last digit in the megahertz segment, thus permitting the user to tune in full, one megahertz increments.
This LONG press, in conjunction with the use of the spectrum scope, (which should be set at it's greatest width, +/- 2.5 MHz) allows for quick tuning across vast portions of the spectrum for observation of areas of signal concentration. This is a great feature of the receiver.
A Little More "Confusion"
In the "kilohertz" section of the display, something different occurs with Long Press / Short Press. A short press places the cursor over the last digit in the kilohertz area, allowing the user to tune in the steps he/she has define and focuses the radio on kilohertz tuning. Another short press and the cursor disappears, thus giving the radio's tuning focus to the hertz section of the display. A LONG press brings up the 'F-INP" (Frequency Input) screen-- the opposite of what happens in the megahertz area.
In the "hertz" section of the display, either a short OR long press gives the tuning focus to the hertz steps. Interestingly, there have been some complaints that the radio does not normally tune down to the final hertz---- the last digit in the display remains "0", unless certain functions like F-INP or PEAK are utilized. Perhaps at some point, a firmware update will allow a LONG press in the hertz area of the display to control that final digit while tuning.
In conclusion, for this particular TIP / TRICK, the main focus is to alert you to the LONG press function in the megahertz area. This entire ordeal is actually less confusing when you have the radio in front of you to experiment-- with a few repetitive manipulations of the presses on the display, you should master this fairly quickly.
All this information is based on Firmware version 1.33. This could change with future firmware updates.
If you have others Tips or Tricks that you would like to share with fellow R8600 enthusiasts, please contribute to this thread.
