wowologist
Certifiable
In our hobby we like to stick metal objects high up into the air ~
YOU *NEED* to stay on top of YOUR grounding situation!!! SAFETY SAFETY SAFETY!!
Here are some pics of what happened when the 'hood had a nearby lightening strike. Now keep in mind the actual strike location was ~1000' from this location. This was just an arm/arc of the main strike that literally obliterated a rather large, really old oak tree.
This was a downlink coax run from a DirecTV sat @ approx 12' above ground. As you can see it served it's purpose (and was destroyed in the process) - the Fire Insp. that came by said it did it's job very well, as if it had not been installed properly, it could have energized the metal rain pipe/gutter system, as well as directly energizing metal components inside the house that people may have been in contact with, causing..well, we'll leave that to Hollywood.
Keep in mind that this is in a normal metro SFH hood with power poles, and ton's other higher objects and ground points. LIGHTNING GOES WHERE IT WANT'S TO!
