TK-2170 Open Squelch
Bryon80
Toccoa, GA
I have some TK-2170 that when transmitted on a Repeater Freq the squelch opens up and we have alot of static with the Monitor on (PL's Disabled). Without the Monitor function on ( PL's Enabled) no static but the green light stays on. This does not happen on simplex freq channels. The kicker to the situation is that I reprogrammed one of the radios with this issue with another TK-2170 program that does not have the issue and the "open squelch" was still there. Anyone have a solution to this problem.
12dbsinad
To narrow things down, first thing unscrew the antenna and see if the "green light" or unsquelch goes away. this eliminates the outside world like RFI, etc...
Bryon80
Toccoa, GA
If I remove the antenna there is no open squelch or busy light. If I attach the antenna back and transmit the problem continues. While te squelch was open I unscrewed the antenna to see if it went away and it did not. I have this problem with 3 TK-2170 and 2 that works just fine. I can sit them side by side and 3 will show the busy "green light" and 2 do not. Open to further suggestions.
LowBat
San Jose, CA
Try checking the squech threshold. Are the ones without the problem set to a higher number?
speedwaysafety
Roseburg, Oregon
if I remeber I had a tk270 that did that as well and I had to take it to a radio tech and he had to do some sort of tweek on it I can't remeber exactly but it went away with the repeated ch never had a problem with that on a simplex ch
