TK-2180 scan add/delete
Colton25
I have a tk-2180 and i love it it's easy to program and works wonders. I have the "S" button programmed as the scan, and the "A" button programmed as scan add/delete. When i stop the scan to and delete a channel from the scan list and hit scan again the channel isn't being scanned anymore which is what i want, the problem is as soon as i stop the scan again for any reason and hit scan again, those channel(s) that were taken out are being scanned again. I know this seems confusing but it can be problematic in a urgent situation when channels i don't want to hear are getting in the way of what i NEED to be hearing. Does anyone else have this problem?
Northern,New York
If the channel is being scanned you will see a black upside down triangle. When you delete the items from the scan list it should not appear. The radio must not be in scan when removing a ch unless is temp delete
Colton25
Yeah i see the triangle, but when i take it away it always comes back when i stop the scanning again. Im wondering if i need to change the scan type from multi to list.
ramal121
Lots and lots of watts
Sonoma, CA
Well there is scan delete and nuisance delete. While you are scanning and the radio stops on a channel in use, you can hit the D/A button to temporary delete the channel. This condition lasts until the scan is disabled and then restarted or the radio is powered off/on. You can nuisance delete multiple channels in a 2180 but never counted what the max is.
To remove a channel from the scan list you'll have to stop scan, step to the desired channel, and hit the D/A button. This will prevent scan stop until the radio is reset by programming, or whatever according to what you have written in the program software.
Colton25
Ok seems like im doing everything correctly, it just still seems to do the same thing
