Tk-2180
Rob_K
Tolland County, CT
Don't you need the 89d?
On my 7180/8180 there is a "wide/narrow" drop down box for each frequency.
BNelson2735
Port Elizabeth N.J.
OK I see the wide/ narrow drop down Will this put the channells in the range I need them? I appologize I am a better firefighter then radio programmer I still dont fully understand narrowbanding I am self educating
scannerfreak
Well Known Member
Indiana
No problem. Remember, you can always report your own post to have it moved using the report button.
Rob_K
Tolland County, CT
Yes, that should do it. I'm not familiar with the software you are using so hopefully someone else can confirm.
ramal121
Lots and lots of watts
Calif Whine Country
Wide/narrow will change the parameters for that channel and will take care of both transmit and receive, so yes this is all you have to do to narrow band them.
Ideally the radio should be checked for proper alignment when switching to narrow, but realistically with this series I rarely a radio out of whack. Kenwood has gotten much better in the later radios with them shipping spot on.
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
Wirelessly posted (Mozilla/5.0 (BlackBerry; U; BlackBerry 9780; en-US) AppleWebKit/534.8+ (KHTML, like Gecko) Version/6.0.0.600 Mobile Safari/534.8+)
Each channel must be set to wide or narrow band. It is NOT a radio wide setting but a per channel setting. Default is most likely Wide. Wide band radios deviate +/- 5KHz, narrow band deviates +/- 2.5KHz.
