Tk-2312 won't scan
FireJeff1997
Hello, I have a Kenwood TK-2312 and I am using KPG-134D V2.3 software. My radio scan worked fine then after I moved some of the channels around and reprogrammed my radio I can not get the scan to turn on. I can add and delete channels to scan but I can not get it to scan. Any help would be greatly appreciated. Thanks
kayn1n32008
ØÆSØ
Sector 001
Did you make any button assignment changes?
Have you set your channels to ‘add’ (per channel) in programming?
FireJeff1997
No I did not make any changes except for added a channel and changed the order of a couple of channels. Some of the channels were set to add and some were not. I am not sure what the default settings are and maybe I need to check a box somewhere that was not checked. Just not sure what to check or uncheck. I only have a single zone for now but was thinking about moving a couple of channels to another zone.
kayn1n32008
ØÆSØ
Sector 001
When you create a new channel, it should default to ‘Add’
Make sure "Scan Add" is selected for the channel.
Make sure your squelch is set correctly (open squelch may stop the scan).
Make sure your "Scan" button is still correctly assigned.
Make sure that the "Scan Type" is set correctly. If you have multiple zones set up in the radio, it'll only scan the zone you are in if it's set to "single". If you want to scan all the zones, set it to "Multiple".
New channels should default to "add", as kayn said.
FireJeff1997
I have checked all of that but when I hit the scan button it just gives me a dull boop and does nothing. If I try and assign scan to another button then it does the same thing. It scanned fine before so I am not sure what I have done, but it is aggravating. Thanks for everyone's help.
ramal121
Lots and lots of watts
Calif Whine Country
This is a fairly simple radio. For scan you'll need two or more channels added (indicated by the right triangle on) and at least one zone added (indicated by the left triangle on). Pressing the programmed scan button should get you going. I can't think of anything else in the radio that would preempt the scan function. I could look at your codeplug if you want.
FireJeff1997
I have tried several different things and I just keep hitting a wall, so any help I can get will be greatly appreciated. I have tried to attached is the the file I uploaded to the radio but it will not allow me. I am not sure what other information you need or how to get the codeplug.
kayn1n32008
ØÆSØ
Sector 001
Save the file to your hard drive, then highlight the name of the code plug and change the three letters after the period to ‘zip’. You should then be able to attach it to a post here(if the new forum software will allow it.
Edit: Check your private messages. I just sent one to you.
kayn1n32008
ØÆSØ
Sector 001
Sent you an email.
