TK-2402 Cable
Muxlow
Super Secret
Middlesex County
Been looking around and cant seem to find this.. Looking for the programming cable pin outs. I have a USB programming cable from a kenwood mobile (one of the maxton cables) that has a broken wire. Sooo figured id snip that off and make that into the programming cable for a TK-2402 but! Cant find the pin outs
I know its done by the 2 pins but what wires go where?
LATA 722
Each of the 2 pins for the speaker mic have 3 conductors, the tip, the ring and the sleeve.
The tip is the very tip of the connector.
The ring is the center conductor, between the tip and the "sleeve" part of the connector.
The sleeve is the conductor closest to where the wire connects.
On the Mic connector:
RXD (Receive Data) is on the "sleeve"
On the Speaker connector:
TXD (Transmit Data) is on the "ring"
You may also need a ground. Ground can be picked up on the "sleeve" of the speaker connector.
