tk-3140 tx issues
SMFD34
Upstate, NY
I have 2 tk-3140's that I have had for a few years. I bought the 2nd one because the older one was developing some cracks in the case that made it impossible to use my speaker mic. I have the software/cable and have been programming both with the same file. I have not been able to get the newer radio to transmit properly, all that happens is the radio will transmit for about 1/2 second then a solid tone will come over the speaker and the led begins blinking red until I power the radio off, then on again. This occurs with 2 separate batteries that both work fine in the older radio. I also noted that the battery indicator remains full and the radio will not "chirp" to indicate low battery. Looking for some troubleshooting advice before I go to a radio shop.
Thanks,
SMFD34
Alarmguy
Former Alarm Guy, turned Radio guy
Deep in the heart of Jersey
I've got TK2140 with a similar problem. Been through two batteries already. Now the latest wont hold a charge and dies when you xmit.
code3cowboy
CA-CZU
Do you have battery save enabled. The 180 series portables have a known problem where the power save feature essentially fails and you have to do a little work with a power supply.
glatts17
Lethbridge AB
I have mainly encountered that problem with bad batteries that is always Kenwoods notification of a bad battery long beep and flashing red light but i have also encountered that problem when there is a VCO unlock issue or a cracked or broken PC board. FYI that is the best part of Kenwoods portable radio design is they have a nice solid die cast chassis and a fairly inexpensive plastic case that your local radio shop should charge a very reason price to replace.
