giles391rescue
On the KPG-89D, under the 2-tone section, you know where you can input the Hz and form your own paging alert tones? Well, I have made my alert tones, and set it to cycle 3 times when the paging is activated. So........when the radio alerts, it will only alert for 1 cycle, instead of the 3 that I programmed it for. So anyway, dispatch says what they need to say, and when the transmission ends, it alerts for the full 3 seconds that it was programmed for. I don't have a clue what else to check. Anybody know?
