TK-3180 Programming Issues
ffemt134
Hello all,
Just got a used TK3180, and hopefully someone can help me out with an issue I'm having trying to program it.
I'm using a cable with a serial port from Wiscomm, and can't get it to even read the info from the radio. I first tried a laptop running Windows XP with a Prolific USB to Serial adapter, and got the message "Check all connections and COM port settings". After that, I tried a desktop computer (also running Windows XP) with a real serial port built in, and got the same exact message.
Anyone know what's going on, or any advice? I'm starting to think it's a cable issue....
jim202
New Orleans region
Hello all,
You need to make sure the program is set to the com port your connecting the cable up to. I would start with the XP machine and make sure you know where the software and cable connections are. Sometimes other programs hog the first couple of com ports and you don't know it.
ffemt134
Yep, I made sure the COM port settings in the software matched what the cable was plugged into.....unfortunately, no luck.
RobertPatterson911
Wellington, Kansas
Make sure you have the drivers for the programming cable, and then check your connection to the radio. Sometimes when I have attached cable to the portable, I have to loosen it a little, then tighten it back down.
kmacinct
Connecticut
Is your cable a USB or DB9 Serial?
Some of the DB9Serial to USB Adapters are very sensitive.....(aka dont work)
