I have come into 3 handsets, 2 are TK-3200s (8 channel models) and one is a TK-3200L (15 channel model.) Whenever I tune any of the handsets to a channel above 3, all it does is put out a tone and flash the LED red/orange over and over. Also, I have noticed that I can't do any of the programming described in the manual that require you to hold buttons while you turn it on. When I try, it just acts like normal, power on beep and then nothing. It should flash the LED after a couple of seconds and announce things depending on what I am trying to do.
On the TK-3200L I was able to get it to do something with the reset-to-default where you hold all 3 buttons while powering on, but I didn't have the volume up high enough to hear what it said, and now it won't reset again; I can't change buttons, reprogram frequencies, or anything else. It's like that on all the handsets (well I say all, but one of the TK-3200s had a dead battery and is in the process of charging, but I am assuming it's going to be trouble like the other two.)
Does anyone know why the handsets are behaving this way? If I didn't give enough information, just let me know and I'll do what I can to give you what you need.
Oh by the way they do transmit on the 3 channels I can get to, and they sound pretty good too!
Thanks for any help you can give!
