TK-3360-K
100pcttn
Dickson,TN
Ok, i must be having a dumb moment or else I've stumbled onto a problem I created for myself 8 years ago when I bought this batch. Dealing with some complaints from one department that some of the older radios "won't communicate with the newer ones" that I've sent them. They sent me 3 TK-3360's back. After checking and trying to program them correctly using my KPG-128 software, it appears they don't have the option to transmit QT/DQT tones, or else I'm going blind and not seeing the proper checkbox to enable! Only 2 "signalling type" options I see are Fleetsync or MDC-1200 as shown below. I can monitor the radio transmission on others, but only if i manually open up the squelch on that radio. Oddly though, these 3 will open up and receive a transmission from other radios using the same frequency and tone. Makes me think they are reading the tone, but not sending the tone.
Any help appreciated as always. Thanks.
N5XPM
Texas
You are working on a radio wide setting. Pick MDC 1200 and press OK. Then move over to the frequency setting by individual channel and I think you will locate what you need.
100pcttn
Dickson,TN
Thanks. I must have done something the last time I cycled thru them and got it. Not sure what, but that's the first time in all these years of Kenwood programming i had encountered not having PL tones on BOTH the incoming and outgoing signal. Not sure how I messed that up! LOL But if one of the admins wants to delete this thread, problem is solved now. Thanks again.
AK9R
Central Indiana
We don't normally "delete" threads. We do sometimes lock threads so no more posts can be made to the thread.
We will most likely leave this thread as it is. The solution to your "dumb moment" may help someone else in the future.
100pcttn
Dickson,TN
Ok, probably just as well. I haven't fixed the problem, i got tricked yesterday by a radio with no PL tones in it. So, I'm still unable to transmit these tones on 3 different radios, all of the same model. Makes me believe I have a programming problem or oversight somewhere. Anyone wanna venture a guess on this as to what I'm doing wrong? As you can see, I have my tones in both the ENCODE and DECODE columns....
If these are older radios, they may be in need of alignment. QT and DQT deviation levels can drift and they may need to be adjusted.
This isn't something you can do without a service monitor, so sending them in to a competent radio shop that has the right tools and experience would be in order. You'd have to pay for "bench time", which could be anywhere from $85-$120/hour. Doesn't take long to align a radio, though.
100pcttn
Dickson,TN
Yeah, that's kinda where my thinking was leading me. I've since found some other radios out here on the plant floor that will communicate with them also, but not the NX-320 on my desk. Thanks again Mr Mmckenna, you've bailed me out before in times past. I have a shop I work with to send them out for repairs that are.... "above my pay grade"! LOL
OK, happy to help.
If you've had these radios a long time, it's probably good to get them aligned periodically. They do drift as components age, and as they get knocked around. The bench time can look expensive up front, but it can greatly extend the life of the radio if it's in otherwise good shape. I do ours periodically and it sort of freshens them up and makes them work like new.
If it's time to start replacing the radios, the new NX-1300NU are nice. I've got a site using those and they've been happy with them. Nice compact radio.
100pcttn
Dickson,TN
Yes sir, I probably need to have some of the older ones tested. And knocked around indeed! Some units look like they've been run over by a freight train. Keeps me busy sometimes piecing them back together. I've been using Kenwoods here since 2000. The ole TK-370 & 372's that we first started using seem to just keep clicking along. Still got over 40 of them in active use. I show having 255 total in use as of right now, and of that already got 9 of those 1300's in use, as you can see below. And 12 active versions of software. Not counting the old DOS versions already retired! Thank you again for your help and wisdom. Much appreciated.
Radio TypeRadio ModelCount
KenwoodNX-1300 NU
3​
KenwoodNX-1300 NUK4
6​
KenwoodNX-320
29​
KenwoodNX-340
8​
KenwoodNX-340U
17​
KenwoodNX-340UK2
42​
KenwoodNX-820H
8​
KenwoodNX-820HGK
5​
KenwoodNX-820HGK2-TD
14​
KenwoodTK-3100
3​
KenwoodTK-3100U16
1​
KenwoodTK-3100U2
3​
KenwoodTK-3170
2​
KenwoodTK-3200LU15P
4​
KenwoodTK-3200LU2P
12​
KenwoodTK-3200U2
2​
KenwoodTK3200U2P
6​
KenwoodTK-3200U2P
5​
KenwoodTK-3202L
4​
KenwoodTK-3302
6​
KenwoodTK-3360
10​
KenwoodTK-370G
8​
KenwoodTK-372
5​
KenwoodTK-372G
28​
KenwoodTK-8160
4​
KenwoodTK-860
8​
KenwoodTK-860G
9​
KenwoodTK-860HG
3​
255​
