TK-350G Question
obijohn
A Question for all of you Kenwood Technicians/Guru's out there...
I have a TK-350G portable that is doing some flaky things, and I know that the product firmware can
get corrupted in these radios.
I need to know if the firmware checksum "F415" is a good one.
Thanks for your help...Obijohn.
MTS2000des
5B2_BEE00 Czar
Latest F/W I have is 64E5, here is LSB0210 says about the firmware corruption problem and how to prevent it.
SERVICE BULLETIN Land Mobile Division
Kenwood Service Corporation 2201 E. Dominguez St. Long Beach, Ca. 90810 (310) 761-8275 (310) 761-8290 FAX
SUBJECT: TK-250/350 Firmware Protection
DATE: 12/30/1997
(310) 605-5045 BBS (310) 761-4498 Direct FAX
Printed in U.S.A.
The TK-250 and TK-350 microprocessor memorizes the user settings every time the radio power is turned off. If the battery being used cannot sustain radio operation, the user settings memory routine cannot be completed reliably. In earlier versions of the TK-250 andTK-350, it is possible to corrupt the microprocessor firmware by trying to operate the radio
with a weak or discharged battery.
Beginning at serial number 704xxxxx of the TK-250 and TK-350, C451 on the display section of the TX-RX unit (X57-44xx-xxC/3) was replaced with a 47k W resistor (Kenwood P/N RK73GB1J473J or equivalent). This resistor stabilizes the reset line when a low battery voltage condition exists - preventing memory errors which could otherwise occur as the radio powers down.
All versions of the TK-250, TK-350, TK-250G, TK-350G, and TK-353 with serial numbers higher than 704xxxxx include the C451/47k W resistor change. Any time that the firmware is upgraded in an earlier radio, or during routine maintenance, C451 should be checked and replaced to a 47k W if this has not already been done.
obijohn
Thanks for posting that bulletin MTS2000des...After doing extensive research, I determined the following...
The firmware progression was (depending on s/n of the radio) F415, 64DB, 64E5. F415 was in radios starting with s/n 811XXX. So I have a good firmware flash. I was able to obtain the 64E5 flash. So I am glad I didn't get anxious and flash my radio with older firmware.
I cleaned all of the interconnect flexes and fixed my problems. It would appear that my radio got wet at some point prior to my purchase. Ya gotta love EBAY!
