TK-370
kayn1n32008
ØÆSØ
Sector 001
Good morning,
I was put in contact with an organization that has no idea about the communications equipment they currently own. I was asked to read their radios, and determine what is programmed, and if it lines up with their license.
All well and good. An easy exercise in reading and saving each radio right? Or so I thought.
It turns out that 7 of the 10 portable radios they own are TK-370 and 3 are TK-370(G)-4. I was not aware of this before meeting with the organizations equipment manager
I had no issue reading the TK-370(G) radios(I own a TK-760-HG mobile), but it seems that it is a different version of KPG than what is used for the TK-370's
I will admit I have not looked overly hard for the difference between the two, I believe that the TK-370 is a wideband only, where as the TK-370(g) will also do narrow band
A few things to keep in mind before responding to this thread:
1. I am in Canada, so narrow band is not required, yet.
2. I am NOT under the jurisdiction of the FCC.
3. I have a copy of their license, so I know what they are allowed to have programmed. Regardless, I am not making any changes. Only providing them with a spreadsheet of what each radio is programmed with.
4. The software Police can just pass this thread by.
LATA 722
A lot of Americans have a hard time comprehending this….
What I was able to find here: Kenwood Programming Information
is that
TK-370 uses KPG-27D
TK-370G uses KPG-56D
KPG-27D covers the following radio models:
TK-260/360/ 278/378/270/370/272/372/388
KPG-56D covers the following radio models:
TK-260G/360G/278G/378G/388G/270G/370G
TK-768G/868G/762G/862G/760G/860G/272G/372G
kayn1n32008
ØÆSØ
Sector 001
Yea, I wanted to stop the 'you can't use wideband' and 'What's your FCC licence' BS before it started. Looks like it worked, as I got a competent reply only.
I figured it would be you or ramal that replied with the correct information I was seeking.
Thank you again mmckenna, your wisdom is appreciated
is that
TK-370 uses KPG-27D
Yea, after I made the OP, that was the same info I found.
Looks like the TK-370 is a DOS software radio only... Time to breakout the old Tough Book, Now I just need to find a serial cable to use, because all I have are USB cables.
LATA 722
Happy to help.
I did check with Kenwood and they don't have have KPG-27d or KPG-56 on dealer tools any more. I'm sure they are out there, though.
Good luck!
kayn1n32008
ØÆSØ
Sector 001
Happy to help.
Good luck!
I'm not surprised it is not available from Kenwood. These are pretty old portables. While I would like to see them get more TK-370G portables, they are in need of 403-430MHz version, which is going to be as hard to find as the pot of gold at thr end of the rainbow.
Alot of that software is in the wild, so I'm sure i will find it eventually. Heck I may even find some one locally that has it.
Again, thanks a bunch. Its great having a couple Kenwood guru's here for help
kayn1n32008
ØÆSØ
Sector 001
CA$65... For DOS software???
Thank you for the link. It may be the last resort for long discontinued DOS software for that price. I have a couple of local contacts that may still use that software. I just hope I don't have to buy a serial cable.
There are lots of TK-270 in use around here still, because we have not been forced to narrowband yet.
