TK-481 900mhz ham programming
bar422
Anyone know what the correct proceedure to program a TK-481 into the 900mhz ham bands? --Thanks!
bar422
I read both of those and put the EZP software in with the data file from the Tk-481 but when I open the EZP software it keeps saying it can't find the data file for the radio. Any more help with this? Thanks!
jland138
San Francisco Bay Area
Not sure what's wrong. Should be very simple. Read the TK-481 with the KPG-35D software. In this software, program the FCC channel number corresponding to the frequency you need using the chart http://home.roadrunner.com/~n2mci/txt/KW900EZP.TXT
Save, then exit the Kenwood KPG-35D software. Make sure you can see file you saved at the DOS command prompt and that the config data is located where you expect it. Fire up KW900EZP with the full path to the saved config. Hit 'E' to verify your work. Exit KW900EZP, run KPG-35D and dump the config into the radio. I guess you've seen the latest for KW900EZP with notes for the TK-481 at KW900EZP
Maybe the DOS 8.3 file name mapping magic is biting you?
bar422
This is still not working.....I am using the KPG-49D software since this radio is a Version 2. I tried to use KPG-35 and it won't even read the radio. Anymore help?
