TK-5210W Programming
NH
I'm trying to program the radio, receive mode only for a couple of P25 channels (everything else I have is analog). I have the NAC. When I uploaded, the radio won't output the received audio stream. I've used the exact NAC (826), NAC F7E and the default NAC 293 - all with no luck. The LED will illuminate indicating traffic on the channel but it won't open. I know that there is voice traffic due to it being received on my BC796D scanner.
If I set the personality to Mixed Mode then the radio will output the audio stream but I only get the 'noise' of the data streams and still not any voice.
I'm using v5.2 of KPG-95DK software.
/Jeff
radiofan1
/Jeff
Current is KPG-95D_V5.41
NH
I'm told that the radio system I'm trying to listen to is a Motorola Astro system and I'll be unable to program it as a standard P25 implementation. First I heard that there was a technical difference between the two.
/Jeff
NH
If you ever run into the issue, the Motorola system in question was programmed in a wide-band mode for their P-25 implementation. The Kenwood software doesn't allow this as an option, therefore resulting in the mis-match.
/Jeff
