TK-5320 P25 UHF 450-520
united781
Does anyone know if the TK-5320 450-520 will program down to the 440 amateur radio band? I have other Kenwood HT's that program lower which allows me to talk on 440 and also listen to public service band.
Much appreciated.
MTS2000des
5B2_BEE00 Czar
Most 450-520 Kenwood LMR will program down to the 70cm band, I have an NX-5320 in that split and it works fine down to about 441MHz but below that the RX sensitivity falls off, BER on P25 and DMR go through the roof, and the VCO starts to unlock at around 437.
united781
That's good to know, I have several TK-3170 and they easily do 444-449mhz. Do you know if the TK-5320 supports DCS and CTCSS I did not see it mentioned in any of the Kenwood literature?
Thank you!
wd8chl
Thank you!
These are commercial radios, not amateur. They have to have CTCSS and DCS. They would be of no use otherwise.
As to programming, the software will complain if you try to enter freqs below 450 on a 450-520 split radio, but just say yes and it will allow it. Whether the radio will take it or not, idk, since I don't have one handy.
And for the other poster, what is an NX-5320? Do you mean NX-5230? VHF P25/NXDN/DMR capable.
Most all more or less modern Kenwoods will do wideband on VHF below about 150 MHz. It's UHF that's the problem.
