TK-5710 Adapter Cable Search
AIA
Oceanside, California
I need to connect a Kenwood TK5710 to a 3010r Intercom. Does anyone know if there is an adapter cable for this or the pin outs for the 12 pin square plug from the remote control head (KRK-6DH) to wire it to the 3010r Intercom?
ramal121
Lots and lots of watts
Calif Whine Country
Firecom makes cables for all the popular radios. Call your dealer to get one for your radio. If you want to roll your own I can provide the pinouts (as long as you have the parts to do so).
AIA
I contacted Firecom and got a quote for the cable. Why is the cable so expensive? I thought it was just a cable with a mini plug at one end and wire at the other end to be inserted with pins at the 12 pin connector.
ramal121
Calif Whine Country
Because they are assembled by hand by qualified employees (?) and they are an accessory item which gives manufacturers a license to bend you over.
If you want to make your own, you'll need the flying lead cable supplied with the 3010, the 12 pin molex shell supplied with the 5710 and several pins not supplied (google Molex pins 0.062"). Here's the drill:
3010 pin # ---> 3010 cable wire color ---> TK-5710 pin #
1 BROWN MIC HI 4
2 RED MIC LO 5
3 ORANGE PTT HI 6
5 GREEN HOOK NO 7
6 BLUE SPEAKER 10
7 VIOLET SPEAKER 11
4 YELLOW and 9 BLACK GROUND 3
In the 5710 programming you'll need to make Function Port>Head>AI/1 = EXT PTT and AI/2 = hook.
