TK-5710 rear accessory connector
wcu02mpa
Asheville,NC
I have recently acquired a TK-5710 and the 9-pin rear accessory connector has been cut off (unbelievable but true). Does anyone know what connector and pin kit I would use to repair this? Also doesd anyone have a link for the service manual?
wcu02mpa
Asheville,NC
manual found
I was able to locate the service manual and the pinout for the connector. What I now need is just to know which color wires go in which pin slot. I can get generic connectors but a factory plug style
The service manual doesn't show the wire colors, but if you open the radio, you can follow the pin numbers…
Pin 1 on the radio side goes to pin 1 on the connector.
Pin 2 on the radio side goes to pin 9 on the connector.
Pin 3 on the radio side goes to pin 4 on the connector.
Pin 4 on the radio side goes to pin 5 on the connector.
Pin 5 on the radio side goes to pin 8 on the connector.
Pin 6 on the radio side goes to pin 7 on the connector.
Pin 7 on the radio side goes to pin 2 on the connector.
Pin 8 on the radio side goes to pin 6 on the connector.
Pin 9 on the radio side goes to pin 3 on the connector.
If you just want the whole thing, order Kenwood Part number: E40-6532-05
