TK-5710 remote head speaker configuration help
djpaulino
Temecula, Riverside County CA
Hello, can someone help with the speaker configuration on a TK-5710 using the remote head. Does the speaker get hooked up to the remote head or radio body? TIA
I am a lineman for the county.
It can be connected to either the control head or the RF deck.
The 9 pin connector on the rear of the RF deck will give you 13 watts of output.
The 12 pin connector on the back of the KCH-15 will give you 2 watts of output. This can be modified to 13 watts output with some internal jumper resistor moves.
If you are using a KCH-14, Kenwood wants the control head internal speaker disconnected if using the external speaker.
On the 9 pin connector on the back of the RF deck, use pins 2 and 6.
On the 12 pin connector of the back of the KCH 14 or 15, use pins 10 and 11.
djpaulino
Ok, thank you . I will try your recommendation.
Rereading what I posted above, I can see where it might be confusing.
If you are using the KCH-14 with an external speaker connected to the rear 12 pin connector, Kenwood wants the internal speaker disconnected.
KCH-15 does not have an internal speaker, so no speaker to disconnect if feeding from the control head.
None of that applies if feeding the speaker only off the rear of the RF Deck. KCH-14 internal speaker can be left connected.
djpaulino
Got it, thanks again.
