landscaperluke
Hello, I am working on setting up a used TK5710 in our ambulance. I have the same radio in our other truck (except the other radio has full feature heads)
I have it programmed and it is all set up the same as the other radio, but it does not transmit. If you key up after about 1 second, it starts to beep (like an error beep)
Here is the ironic part, it will transmit on one of the channels but no other . It does not even start to TX on the other frequs, it just beeps. I have checked and double checked, and checked again to be sure the programming is correct.
I wrote a new program, and tried to load the program from the other radio and still nothing.
The radio had a headset adapter connected to the DB25 port on the back. Would this cause any issue?
I did make sure those settings were at default in the FPU.
When we first picked it up it came with full featured heads and found out these were the wrong head (they were off a tk-790) and they just would not communicate with the FPU software. So I swapped head with the one in the other truck and it programmed up just fine.
So thats when I thought all was good. Installed it and no TX except for the one channel I mentioned earlier....
Since getting the right control heads. it reads and writes just fine, so im thinking i'm probably missing something very simple, but I am stumped nonetheless.
Any suggestions or ideas??
