TK-7150 6-pin plug
wcu02mpa
Asheville,NC
Can someone tell me the 6-pin accessory plug part number (from Mouser) for a TK-7150/8150? or any other place this can be obtained? Also making sure I jumper pins 5-6 for internal speaker??
wcu02mpa
Asheville,NC
Pins??
I completely forgot to ask about the pins. I have some pins that fit the X30 series' plugs. Are they the same or which Mouser pins are correct? Also thanks KC0WKP for connector info...
I really like the TK-7150 radio; underated and can be bought for really cheap. I got one for $100 delivered from fleabay and a mic was included. All I needed is the connector. I found a remote kit for less than $40 and I already had a remote cable. I think this is going to replace my analog spectra in my vehicle.
ScanWI
MN & WI DB Admin
Wisconsin
I am not sure about the pins I believe they are the same.
As far as them being cheap and underrated, there is a reason for that. The radio has a known flaw and a serious one at that. The radio will randomly put out a long "0" DTMF tone on channel one. There is no warning and the user has no indication of the transmission.
This is just something to note, I do not know if there is a fix out there for this or if there is a newer version that this has been fixed in.
wcu02mpa
Asheville,NC
Wrong plugs
Those are not the right plugs. They are too big. I have plenty of them if anyone needs one. Can you verify which ones are the right ones??
ramal121
Sonoma, CA
Kenwood uses Molex connectors of the 0.062 size. Pins are all the same, shell varies with the number of circuits.
cabletech
Puget Sound
Contact your local Kenwood dealer and tell them you need the 6 pin accy connector with pins.
They are available thru a dealer. +/- $5.00 each
ramal121
Sonoma, CA
All the socket plugs in the link I gave will fit. The difference is color and whether they have mounting tabs or not.
