TK 7160 power problem
FireZingr
I accidentally hooked up the power backwards when changing out some wiring and now it won't power on. Is there an internal fuse I can check ?
ramal121
Lots and lots of watts
Calif Whine Country
The radio has a protection diode that will blow the power cable fuse usually. Have you checked and is it bad? Otherwise there is a SMT fuse on the circuit board that will also prevent the radio from powering up.
FireZingr
I just ended up taking it to the local radio repair shop after I took it apart and didn't see a easily changeable fuse.
