TK-730 G narrowband question
Asmitty0010
New Hampshire
Trying to program my TK-730 G for the national V-call freq. It is a narrowband freq (155.7525) but it will not accept it. The software does have the Wide/Narrow option. When i put the freq in it goes in as 155.750. It will however accept V-Tac 1 freq which is 151.1375 with no problem.
Any fixes to this?
ramal121
Lots and lots of watts
Calif Whine Country
To use your example 155.750. The next valid 25KHz channel is 155.775. If you half the channel spacing to 12.5KHz and stick it in between these two the freq would be 155.7625. That would be a valid entry for the software.
Not sure why they made V-call 155.7525 at this time but here's a quote from the ICS FOG:
4. Important- Some radios do not function properly on the following channels: V-CALL,
V-TAC 2, and V-TAC 4. Note: Communications Unit Leaders should not assign those
specific channels for incident use if it might be possible that Bendix-King EPH radios
(including the current NIFC, CDF, and OES cache radios) might be utilized on their
incident. Prior to use on an incident it is important to determine whether or not another
manufacturer’s radio models have V-CALL, V-TAC 2 or V-TAC 4 functioning problems.
vorndamr
Tk730g
Firast make sure that when you go into your software you use the correct model number. This is software defined. You should see the option for narrow or wide if you pick the right model. The TK-730G will do the frequency you are trying to enter. I have it in mine. Rod
dapaq2
Northwest Indiana
I tried to enter 155.3675 Mhz into my Kenwood TK730G and it rounds it off to 155.365 Mhz. Anyone know if my radio is suppose to be capable of allowing this freq. I selected Narrow and tried again and same thing. If there are other frequencies programmed in that are wide band, do all the freqs have to be narrow band or can i have mix match types in the radio? Wondering if the existing wide band freqs are affecting trying to enter 155.3675.
Doug
b7spectra
EMS Dispatcher
Cobb County, GA
G models are the Kenwood narrow band radios. I have a 830(G) and all of my UHF frequencies, so far, work just fine.
dapaq2
Northwest Indiana
Yes I am aware what the G means. Ok, You have a uhf model 30 series, but can you help us with our TK730's as to why they are not accepting the desired frequencies?
Doug
ramal121
Calif Whine Country
Programming a channel narrow will not change how the frequency can be entered, it only causes a different IF filter in the receiver to be switched in or out.
In wideband mode, VHF channels are 15KHz apart and UHF channels are 25KHz apart. To hit every possible combination of 15 and 25 channels you'll need a PLL step size of 5KHz. This is what the TK-X30 series uses and any frequency evenly divisible by 5KHz can be programmed into it (155.360, 155.365, 155.370 etc).
Now the UHF band has for many years has allowed channels in between the normal 25KHz, used to called "splinter" channels. To hit these splinter channels the frequency step needs to be 12.5 KHz. All TK-X30 radios allow 12.5 steps also ( 460.000, 460.0125, 460.025, 460.0375 etc) but that is all they will do.
With narrow banding we have channel spacings of 7.5KHz (half of VHF 15KHz) and 12.5KHz (half of UHF 25KHz). The maximum frequency step that can be used to cover all channel combinations is 2.5KHz. The program software has error checking and won't allow all these new 2.5 channels.
b7spectra is OK with his UHF as this has been in place for a long time, but splitting 15KHz VHF channels is fairly new and was not on the radar when the 30s where designed so the short answer is you will not be able program certain channels unless someone hacks the software to accept the new channels. You could enter the rounded off freqs and warp the radio 2.5KHz to make it work, but then any of the old "normal" freqs would be off.
MTS2000des
5B2_BEE00 Czar
vip3r82
Lloyd KY
Does anyone know where to find the wiring diagrams for a 730g with remote head?
and as well as the programming software & Cable?
