TK-780 and 880 programming Was: Got a radio n computer wont work with us 😡
KF0AWL
Hobo
Iowa
There isn't much uhf going on or even vhf round here right now.
Plugged the 780 in for a scanner tho and thats working excellent. In same mode so must be good
hill
Middle River, MD
Your channels that you have enable to be scanned will have a triangle besides the channel name.
I always have my Kenwoods just to revert to the selected channel name. Also have them programmed to transmit on the selected channel during scanning.
wwhitby
Autauga County, Alabama
You'll be happy with the 780 and 880. I have one of each in my car, but they will soon be replaced with a 7180 and 8180 and they will become scanners at home.
KF0AWL
Hobo
Iowa
Ok now im trying to use the computer in the shack to program them and again running into the drivers for usb issue. This time its windows 7 and not 10.
I don't know were I found the drivers first time because I was half asleep n just got lucky.
Anyone point me in the right direction?
a417
What is the make / model of the programing cable, or any descriptive information off it ..if it's not OEM kenwood.
KF0AWL
Hobo
Iowa
Im not sure of the model! Might have been home brewed I think.
Im trying to be lazy n not haul the power and radio down the stairs to use the computer I managed to program them on the first time.
a417
is there anything identifiable on the cable? Can you give us the Hardware ID (as found in the device manager --> [cable] --> details --> Hardware IDs)?
KF0AWL
Hobo
Iowa
Cable has NO identity, only thing I can tell ya is it has a white, green, and black wire in the radio head plug and the USB has tape on it because it won't stay shut. Thats why I think home brew
This is what I have in device manager
a417
click on that device --> Details --> Properties --> scroll down to Device IDs
a417
well if thats the device that enumerates when you plug it in, thinking it might be the USB cable...yes.
KF0AWL
Hobo
Iowa
I ug it in computer dings and nothing happens!
Same thing I got before on other computer before I somehow got it installed correctly
Sidney, MT
Type device manager in lower left search bar
open device manager
Go down to ports (COM & LPT)
Pic whatever your program cable is and open
Go to port settings
Advanced
Change com port number to com1
KF0AWL
Hobo
Iowa
I open device manager and get this.
No ports you speak of unless you mean usb
If its usb I open that and get the second photo.
Even there if I plug or unplug the usb cord the manager 🤔 squeezes shut to the top (best way I can describe it) then drops back down with no change i can see
Sidney, MT
Did you try opening it once you knew which one it was and click on port settings and advanced?
