TK-780 and 880 programming Was: Got a radio n computer wont work with us 😡
KF0AWL
Hobo
Iowa
You asked if I tried opening it once I knew what one it was and go to advanced.
How do I figure out what usb the radio is connecting to so I know were to go into the advanced and change the port
I really appreciate your help on this by the way.
KF0AWL
Hobo
Iowa
No if I unplug ANY usb device while the manager is open it collapse and reopen but it don't show any difference on the manager list.
Does that make sense?
a417
the offending device is probably under "Other Devices" and is listed as what appears to be FT232 UART USB
Sidney, MT
I don’t have any cables in the house with me right now. I buy my cables from BlueMax49ers on eBay and have had really good luck with them
KF0AWL
Hobo
Iowa
🤷 this what he always used to program them and it worked on the other computer so it should work here to. Just wants to be stubborn lol
KF0AWL
Hobo
Iowa
Nope updated n still no com port.
Going to hit Google again and see if I dig anything out.
KF0AWL
Hobo
Iowa
Ok for anyone that has this problem in the future follow the previous post to install ports then follow this link to install drivers for Kenwood radios!
AK9R
Super Moderator
Central Indiana
That's a driver for the Silicon Labs CP210 chip built into some Kenwood amateur radios.
From the screen captures you've provided, you need a driver for an FTDI FT232 chip. Different company, different chip, therefore, different driver.
Frankly, you can keep beating your head against the wall trying to make your unknown and, apparently, damaged cable work. Or, you can buy a new one. I've had good luck with Valley Enterprises cables such as this one: Kenwood 8-Pin Mobile Radio Programming Cable USB FTDI KPG-46
KF0AWL
Hobo
Iowa
It works! If I did it wrong then I figured a new way to work around a issue because they are both up n running lol
