TK-780 Programming Question
usfsengine
Alturas, CA
Hello. I have a TK-780H that I would like to program myself. I understand I need the KPG-49D software. Im currently running Windows 7. I also know I need cable KPG-46. The question I have, plus probably many more. Would I want to get the USB or Serial cable? I have heard that the 49D runs off of DOS, so would the USB cable work?. Also does the 49D run on windows 7? I think the latest Kenwood software is v 4.02 thats what my Kenwood dealer was telling me. Does this come with the firmware or is that another software? Thank you for everyones assistance in advance.
svfd17
Spring Valley NY
Not knowing much at all about the radio, I would go with the serial cable. I'm not sure about the firmware either but I have never used a USB cable at all and honestly I don't intend to as it appears they are nothing but trouble. Hope this helps.
Sent from a rotary phone
jim202
New Orleans region
You have probably answered your own question about the USB cable. DOS does not support any USB devices the last time I checked. The drivers are just not there.
As far as the KPG-46 software goes, can't help you there. Don't have it, so can't advise you if it works on Windows or not.
usfsengine
Alturas, CA
Do you suppose it would work on Windows 7?
svfd17
Spring Valley NY
I really can't say, I've only dealt with the Kenwood tk2140 and 3170. It's worth a shot if you have nothing to lose. Another option is to actually call Kennwood yourself and inquire about that. Sorry I can't help you further sir.
usfsengine
Alturas, CA
I think I found out my answer. I had a pm from another gentleman that the 49D does work for Windows 7. I guess I'll need to purchase this stuff. This will make my fire chief pleased. Were done waiting for the county radio techs to give us an updated program. Some of our channels are still wideband, yet the repeater is narrow.
svfd17
Spring Valley NY
Glad to hear! I hope everything works out for you and your dept.:)
ffmedjoe
Land of Cheese
You want the software 49Dv401 it works fine on all windows. I haven't used it on windows 8 yet. I'm not sure what Kenwood charges for CPS anymore and the usb cable is no more than $20 on ebay.
usfsengine
Alturas, CA
So I got the software and a cable. Now I need a little help with the OST feature. Is anyone an expert with that? I have inputted my 16 standard tones on the OST tab in the 49D program. When I have a repeater and it is tone protected on the TX side, do I select none on the OT/DQT Enc? Any help would much appreciated. Thank You.
ramal121
Lots and lots of watts
Calif Whine Country
The radio will use the decode/encode tone you programmed along with the frequencies in the channel edit screen. When you invoke OST, both the decode/encode will be replaced by whatever pair you select from the list.
For fire service you'll need to put all 16 tones in the ENCODE column and leave the Decode column all as "NONE". The reason to leave decode off is you will need to access different repeater "groups" on different channels and they may have different tones on their transmit and you do not want to have your receiver locked to any one "group". By having decode off, you'll hear any transmission on the channel. The OST will then use encode only to steer you to the correct repeater on that channel.
usfsengine
Alturas, CA
A little update with my 780. Received the USB cable works great with windows 7. Figured out the OST and DEC tone side of things. Works awesome. Thanks for everyone's help.
BUCKKO
Lakeview
I need to know if you can program ( field program ) has been modded when I bought it want to program the name like ( FIRE---CAB---TRUCK----FIRE etc ) in place of just the freq numbers? Thank you
jim202
New Orleans region
I believe you will need the KPG-49D software to program that radio using Windows. You will also need a programming cable to go between the radio and your computer.
avdrummerboy
Mohave County, AZ
The alpha tags? Yes, the KPG-49D will put alpha tags in for you. As to the above, I use windows 7 and a USB cable to program my TK-981 (same family as all of the x80 series radios like the 780 you're using.) There is a DOS version, and yes, DOS doesn't do USB and a GUI version. I prefer the GUI haha.
