TK-790 basic head 45 watt
scanner1
Looking for some info on the pinout on the rear of this radio. The radio has the 9 pin square accessory plug on the back. Currently pin1 is used for ignition sense and pin 3 and 6 is jumped for the internal speaker. I want to hook up an external speaker. I was told i should remove the jumper for the internal speaker and run the external speaker from pins 2 and 6.
Wanted to check in here first. The radio is a new 45 watt with basic control head.
-Thanks.
Theroofable
If thats what it says in the manual, I cant remember what pins but it matches what the manual states.
mrweather
Yes, the external speaker plugs in at pins 2 and 6.
Warning: do NOT ground the speaker or you'll blow out the audio amplifier.
