tk-790 help
hacker7452
clinton,tn
hope you all can help i got a tk-790h and sometimes when i key it up it will make a beep sound. but still able to transmit. is there any thing i can do to fix that cause when it beeps it makes me think that our repeator is on battery reserve. and im tired of goin up there and checking it any help would be nice
mrweather
I'm not understanding the question.
When you key your radio it beeps? Is it a long tone (for as long as you hold the PTT) or a series of chirps?
The long tone means the channel has been programmed as receive-only. A series of chirps means the radio VCO is out of lock.
hacker7452
clinton,tn
well i guess you could call it chirps and it only does 2 of them. and what does out of lock mean this is the only radio that does it
mrweather
"Out of lock" means the electronic component in the radio (the "VCO") that is used to generate frequencies that are used for transmitting and receiving is malfunctioning. That happens when you try to use a frequency that is outside of the usable range of the VCO.
The fact that you're getting only a couple of chirps means you're right at the edge as far as frequency goes but the radio will still transmit.
hacker7452
clinton,tn
ok then why would it be out of range for the radio the freq is 153.890
EZlistener
Tennessee
There may have been a component failure (capacitor, resistor, etc) affecting the tuning of the radio. You may need to have a shop familliar with these radios check for this and re-tune the radio for optimum specs.
hacker7452
clinton,tn
well i may have figured it out my squelch was set to 5 and i bumped it up to about 10 so as of right now it is doin fine i think
mrweather
You may also have the transmit inhibit feature activated on that radio. If a signal is being received, pressing the PTT will give you a tone (not a chirp) and the radio won't transmit.
