TK 790 mobile wiring
midstate33
Gassaway, WV
I am trying to get a Kenwood KMC 30 mic to wire
to the DB 25 connector on rear of TK790, have
PTT but no voice anyone who has been successful
with this I would greatly appreciate any help
Tnx W8WAR
LATA 722
I don't have my software here, but you should need to set up the Mic Input to use the port. On the newer radios theres a page for this on the KPG that lets you assign the rear mic input for data or voice.
n7maq-1
Oregon
You need to move R641 to R640 for mic audio.
MI/DI (MIC Signal Input/Output or Data Audio Input)
This pin has one of the two functions listed in Table 3 by
setting jumper resistors (0 ohm) R640 and R641 on the
control unit (X57-561 B/3) (Refer to page 21).
1) MIC signal input/output
This pin is directly connected to the MIC input pin of the
transceiver, so it has the same function as the MIC input
pin. When the input is 5mV/3 kHz, DEV (600 ohms)
modulation is obtained. The MIC input is output from the
transceiver panel as it is.
2) Data audio input
The signal from this pin passes through the LPF (fc: about
10kHz), is summed with the MIC AMP output, and goes
to the modulator. Therefore, it is not preemphasized.
midstate33
Gassaway, WV
Ok guys really appreciate the answers/help but I have tried the things you suggested, I should have added that by applying signal from function generator and keying mic I have good transmitted audio, I also applied dc voltage to appropriate pin on KMC 30 powering the electret in mic (?) I believe there is a switching problem in the mic circuit preventing audio getting to db25 mic input pin, the KMC 30 works just fine on tk7180, really got me stumped, any help is appreciated, tnx 73’s
W8WAR
ramal121
Lots and lots of watts
Calif Whine Country
So you did switch/confirm the internal jumpers? If the radio is set for data you can still pump audio in but at a much higher level than the mic element will ever produce. Input absolutely needs to be set for "MI".
The grounds for PTT and the mic element are separate and you need to connect both. Pin 3 "E" and pin 5 "MIC-E" need to go to the respective pins on the 790 25 pin connector.
midstate33
Gassaway, WV
2) Data audio input
Done
ramal121
Calif Whine Country
A certain sheriffs office wanted a second mic on the passenger door so they can stand up out of traffic and use the radio. 790's with KMC35. Installed lots. Any Kenwood mic should work.
