tk-790 narrowband problem
gee305pipd
maine
Hello, having problem with two tk-790 radios changing over to narrowband. 2 out of 10 Kenwood TK-790s I have done are giving me a problem. When I change all the channels over to narrow, the radio will not receive when the mike is on hook. It will if I turn monitor on but not otherwise or when the radio is on SCAN it will not recieve either. Works fine when mike is off hook though.
The only thing i changed on the radio is from wide to narrow on each channel. For the heck of it I change the radios back to wideband to see what would happen and it work properly again. Any thoughts you have would be appreciated.
jim202
New Orleans region
You might want to give the Kenwood tech service a call and talk with one of the techs there.
My first guess is that the Kenwood tech will ask for the model and serial number of the radios in
question. His next statement might be that the radio is a model version one. That is the worst
answer he can give. This generally means that it doesn't have all the functions of a newer version
radio. The version of the radio can not be changed. It is just the way the circuit boards and the
memory were made.
Will have to wait and see what the outcome is for your radios.
Jim
gee305pipd
maine
Thanks Jim,
one radio was bought new in 2001 the other 2007. I even tried the codeplug from another radio that does work in each of these radios and still the same problem.
jbcord
It sounds like the radios need to be tuned. You can go into tuning mode on the KPG-44D software and check it. Just make sure to change the mode to narrow before you change your settings.
