TK-790 not getting audio from the remote head
rellis73
Lincolnton, NC
I have a TK-790 with a single basic function head installed. I am not getting any audio whatsoever to that head unit. I have checked all the connections and cannot find any problem. Am I missing something somewhere?
ramal121
Sonoma, CA
First guess, you're missing jumper for speaker audio. Its a 9 pin molex connector with a white wire loop in it. Plugs into the back of the radio.
ramal121
Sonoma, CA
One side of the audio amp shows up at the rear acc connector. A wire jumper turns it around and ships
it back to the control head. This gives you the choice of hooking the speaker to the head or the chassis.
Look at the back of the radio (antenna on the right, power cable on the left). The 9 pin connector goes like this;
Right column top to bottom, pins 1, 2, 3 (next to the indents).
Middle column top to bottom, pins 4, 5, 6
Left column top to bottom, pins 7, 8, 9
Place a jumper from pin 3 to pin 6 for speaker at the control head.
For a speaker from the back of the radio, remove jumper.
Speaker wires go to pin 2 and pin 6.
Piece of cake....
