TK-8162 receive problem
soDimmmm
Netherlands
Hi there.
There is a problem with my TK-8162
It receives, but to hear it you have to press the monitor -button.
The green "receive" LED lights up allright, so the signal is strong and the squelch should be opened automatically, and not by pressing monitor.
ramal121
Lots and lots of watts
Calif Whine Country
You have a signalling option turned on and the transmissions are not matching what is programmed
in the radio. Are you using QT or DQT decode and is it correct? Have you enabled another option
signaling (fleetsync, DTMF)? All these would require the proper code (if they are set up that way)
before you could receive. Obviously the monitor defeats the signaling requirement.
