Hello!
Can someone please explain how this works:
Our GMRS group is considering using Fleetsync to set up the following calling abilities:
1) ALL CALL (All members)
2) Admin All Call (Group call for all Admin at the same time)
3) Individual call
4) Family All Call (Members of the same family having an "ALL CALL" feature)
I am having trouble figuring out how to use the Fleet and ID's to accomplish this, and am wondering if the Group ID 1-10 can help. I'm not even sure how this works, or how you place calls to that group.
-I figure an ALL CALL is as easy as "ALL / ALL " in the ID List.
-Admin ALL CALL is as easy as assigning each Admin member a radio with the same ID, but having them use their family Fleet ID to segregate their radios from the group. That should look like " ALL / <Common Admin ID>"
- Individual call is self explanatory, " xxx / xxxx " for each individual Fleet and ID.
-What I am having trouble with is the Family All Call. For general members, this is not an issue, as it is a simple " <Family Fleet> / <ALL>." But what complicates it is giving Admin the ability to not only Admin ALL CALL, but also Family ALL CALL. To make matters worse, some Admin would like to have 3 of their 5 radios alert on an Admin ALL, but also have the ability for each of their 5 to individual call any radio in their family fleet. In other words, not triplicating the Fleet and ID in the 3 radio, but rather having a configuration in them that allow that (not sure what that would look like).
I figured you could program all 3 of those with the same <Family Fleet> / <Common Admin ID>, then program the other 2 with <Family Fleet> / <xxxx>. But what happens when you do that is when you key one of the 3 radios with the same ID, it alerts the other 2 regardless if you are trying to individual call them or not, as the other 2 radios interpret the data burst as an individual call rather an a PTT ID.
I'm not sure if there is a work around for this, or if the Group ID 1-10 could help. I have no idea how to use or make calls with Group ID 1-10, so any help would be much appreciated. I am hoping it is possible for that Admin member to not have to triplicate his Admin radios, rather give them individual call capabilities without the contention.
Thank you in advance for your help!
3) Individual call
