TK-8180 Power On Volume
Colton25
I just programmed my new 8180 and i noticed something different then what my 7180 does, when the transceiver powers on the volume automatically goes to 7 no matter what i change in the volume settings, here's a screenshot of the settings i have now. I'd like the transceiver to power on at a lower level because 7 is just too high.
ramal121
Lots and lots of watts
Calif Whine Country
The way minimum volume used to work is if you set the volume lower than the minimum level at power off, the radio would raise the volume to the minimum level on power up. If you had a volume level higher than the minimum level at power off the radio would maintain the same at power up.
Now you have minimum volume type set as "lowest limit" instead of "preset" which sounds like what you want by the help file, but I'd have to play with it to see exactly what it will do.
