Tk-8180
scanfan03
Houston, Texas
I have a problem with my TK-8180 and I can't figure out if it is a programming issue or not.
I set it up to scan multiple groups and it only seems to scan the LTR systems. It doesn't scan the conventional channels that I have in it. All of the channels in the radio are added into the scan list, but it doesn't scan the conventional channels. Anybody know what I might have to change?
I have a TK-3180 set up the same way and it works perfectly.
You might check the off hook scan feature.
If the mic if off the hook and the Off-hook Scan check box is not checked (in the scan information window) then the radio will not scan.
Although now that I think about it, this really wouldn't explain why its scanning the LTR and not conventional.
One thing you may try is check to see if the conventional zone is turned on to scan.
Go to your conventional zone and see if there are two triangles on the display. One triangle indicates if the individual channel is in the scan list, the other indicates if that zone is in the scan list.
If the zone is not turned on to scan then the channels within the zone are not scanable.
Thats my best guess. Anyone else have any ideas?
scanfan03
Houston, Texas
There's 2 triangles on the conventional zones. It has me puzzled because it's set up the same way as my tk-3180 and I don't have any problems with it.
kmacinct
Connecticut
Not sure if you can scan across LTR "AND" Conventional at the same time.
Might have to load your conventional channels to look like an LTR Group maybe?
Thought I heard this somewhere before...
Gezelle007
Lurker in the Deep
Oregon
I agree. However you might be able change the scan type to "Multi" by going to Scan Information in the Edit tab in the Fpu. That should make it scan every CH/GID programmed to "Yes" in Scan Add.
