TK-8180
DTilman
Humboldt, KS
Hey guys,
I'm trying to program police radios for my agency and i have downloaded the kpg-89d software to my computer. My chief had bought a used radio that looks like it was from detroit from the naming of the stations. But to my question. I can not read my transceiver with this program. Can someone help me please. And yes this is my first time doing anything with radio's like this. It is a kenwood tk 8180 by the way if that makes any difference.
cmjonesinc
You need KPG-89DK. 89d is for the European radios.
DTilman
Humboldt, KS
Hey cmjones,
I know this software should work because there was someone at my department that did program a radio with it. Don't know how it worked if this software is supposed to be for European models. If you have any suggestions on what I could do I would greatly appreciate it.
PS I know this sounds kinda snarky but that's not my intention. Just not sure how to word it to not sound snarky sorry
ramal121
Lots and lots of watts
Calif Whine Country
Well what happens when you try to read the radio. Do you get any kind of error message? What kind of cable set up are you using (USB or serial)?
DTilman
Humboldt, KS
I get a check com port settings or cable connection. What they gave me was a double ended port connection. Same type of connection on both ends of I sound like I have no idea what I'm talking about. I did get a USB cable but haven't been able to try it out yet.
ramal121
Calif Whine Country
Hmmm. The normal program cable has a plug that fits into the mic jack and the other end would be USB or it's older a 9 pin serial connector.
If the cable you're using is the same on both ends, where are you plugging it it into? The accessory connector on the back of the radio and a serial port of the computer? It can be done this way also.
First you need set the correct com port that the ccomputer uses for that cable in the software. You can locate the com port in the device manager in windows. If you're lazy like me, in the program software setup menu you can click on com port. You may see several active. Try each one until you find one that works.
DTilman
Humboldt, KS
The cable plugs into the mic Jack and I had a port on the computer it was fitting into. Maybe that was my problem. When I open up the com port settings I only have one option so I don't believe it is that. Lol. I will try the cable that I bought for it with a USB plug on it. I appreciate all your guy's help. If the new cable doesn't work I'll holler at you guys again.
Dtilman
