TK-830 Plug and Inversion questions
N_Georgia
First I purchased several 830s with speech inversion module and standard head. I have now purchased another no SI 830 which has a remote mount head. Can I unplug the inversion module and plug it back into the remote head radio or this there other modifications to the radio that make the module work (jumper or soldering). If so I will just swap the remote head over to the other radio.
Second, the remote head is designed to have the speaker pluged into the back of the head. There is a jumper on the back plug on radio it is on the top row of the plug in the middle. I am guessing this may have something to do with this. Can I just remove the plug(jumper) and plug the speaker into the original plug. The way that I am installing this I need the speaker to be with the radio and not the head.
Thanks for all the help.
Ryan
N_Georgia
basically my first question is can I just pull the inversion chip and put it right into another 830 with no further mods?
radionerd13669
Useless Contributor
Northern,New York
Most Kenwood radios require a mod for the plug in scrambler module. If you knew the brand of the board that would help.You can go to Midians or selectone and brouse over app notes for that radio that may help you a little
N_Georgia
I have been told that it is a transcrypt I have email them for some info.
I was hopeing that someone on here will be able to recognize it. There are two diode/jumpers that cut around where it plugs into the board. That is the only thing I see.
RayAir
You might want to check if the original audio path was cut. I know on ICOMS's if you install one of their scramblers you have to cut the audio path because the audio is now routed through the scrambler board.
That's probably the only mod you might have to do considering that is a plug-in board. Examine the paths on the boards carefully to see if one has been cut.
