TK-862G (N) -1 and KPG56D Problem
nicknoodle
Hi guys, recently purchased 2xTK-862's (UHF) and would like to reprogram them (obviously).
Fired up KPG-56D selected the model stated on the back of the rig UHF TK-862G (N)....
(In KPG56D is says TK-862G(N) E), Tried to read from radio and KPG-56D says that I have selected the wrong radio.
This happens with both radios, which both have been programmed previously by the same person as they tx/rx same chan/freq etc.
Tried 2.2 and 4.2 windows and dos different machines, using a serial cable, com1 is selected, I have now run out of ideas.
Any help appreciated,
Nick
code3cowboy
CA-CZU
You dont need to select anything other than read, the software will tell you which radio you are reading.
nicknoodle
The software is telling me I have the wrong radio selected.
It reads the serial number off the radio but no channel information?
ambdrvr
KPG56D Problem
Hello,
Have you tried to select a different model and then read the radio? When I open the KPG56D software it shows that there are 3 different 862 models. It's just a suggestions but maybe try reading the radio with each of the different model types and see if you get lucky.
Ambdrvr
nicknoodle
Hello,
Ambdrvr
Yes I have also tried this, I know the cable is working because it read the serial number from the radio, also it programs my TK-809 fine, and numerous handhelds.
wcu02mpa
Asheville,NC
Try this.....
I have ran in to several Kenwoods where I was not able to read the radio, but was able to write to it. Try selecting the model and put a few freq's and tones in and then write to it.
