TK-880 for ham band
KJ4YVN
Miami, Florida
can someone confirm if there is a special tool to adjust VCO or is it just a flat head screw driver. any direction will be greatly appriciated
KJ4YVN
WX9EMS
Lake Geneva, WI
It is a very small one at that! You also need to exercise caution as well though. The trimmer caps are extremely delicate and can be damaged quite easily. Once damaged, the radio will be inoperative on either transmit or receive depending which trimmer cap was damaged. I am not so sure you need to adjust the VCO for Ham use, unless you are having VCO locking issues. You will also need to monitor the voltage of test point TP1 at your lowest frequency in both transmit and receive. I strongly advise getting a copy of the service manual before you begin on your adventure.
WX9EMS
Lake Geneva, WI
I have used a small jeweler's screwdriver with part of the tip shaved off to fit the trimmer cap. The reason I know this, I did damage a trimmer cap and I completely disassembled the VCO unit and modified my screwdriver tip to fit properly so it wouldn't happen again. I have since tuned about 15 units with this modified screwdriver and have had no issues since. I also put heat shrink on the shaft to insulate it while in the hole to prevent any short circuits that may arise.
This is what works for me, it may not work for you. Your mileage may vary.
