TK-880 intermittent scan
arlo
I have a TK-880 that only scans when it wants to. Problem is not mic or mic holder.
Radio is programmed and operated like a good radio. What should I check next?
tlemke940
Lyons, OR
try tuning on "off hook" scan just to rule out the hook line. just to limit the test area. i have seen mic jacks and the hook line have problems before.
AM909
Radio/computer geek
SoCal
What does "only scans when it wants to" look like? Do you mean it won't go into scan mode? Is the "SCN" indicator in the display on or off? When you press the SCN button (or whichever one is programmed to start/stop scan), does it beep? The most commonly replaced wear item in this radio is the rubber keypad (especially the original black ones) – if some key functions produce no beep, that's the problem.
