TK-880 - power up problem
Mike-KC8OWL
Henderson, NV
Today, after making some programming changes to my UHF TK-880 and uploading the changes I found that the unit would not power up unless I had the programming cable (connected to the serial port of the PC) plugged in to the mic jack. As long as the programming cable is plugged in, the radio will power up but when I plug in the mic (or leave the jack empty) the radio will not power up.
Has anyone ever seen this before? If so, what can be done to fix the problem. This is odd because the radio has worked fine for quite a long time prior to this.
Thanks .... Mike
ramal121
Lots and lots of watts
Calif Whine Country
Never have seen that, but my gut swag says you are missing a ground for power and somehow the
progrmam cable provides this when plugged in???
fineshot1
NJ USA (Republic of NJ)
I have seen a couple of these fine radios get the cpu gliched once in awhile.
Try this - disconnect power and let the radio sit awhile(about 5 minutes).
Reconnect power and try powering up again. If there is nothing wrong
internally with the radio or power wiring problems it should power up again.
