TK-880 Question
miller46
New Florence, Pa
I am using the KPG-49D for Windows for programming, and I key up on the radio on either channels 1 or 2 in group 1 it will go to channel 3 to transmit. Can anyone tell me why, or point me in the right direction to getting it so I can transmit on channels 1 and 2?
ramal121
Lots and lots of watts
Calif Whine Country
Under "channel edit" see if the "data" box is checked. Uncheck all channels used for normal voice transmit. Common whoops...
ramal121
Calif Whine Country
If a channel is set for "data", it will be used by the external PTT from the KCT-19 accessory connector (ie if a gps modem is connected). If you press the mic button PTT, it assumes you want a voice channel and switches to the first non-data channel. In your case channel 3. A real hair puller, but I've learned my lesson. Glad to help.
