TK-880 Receiving Through PL Tone
Seven-Delta-FortyOne
The Emerald Triangle
I have a TK-880 as a base station, and it receives as CSQ on my channel, even though I have a PL tone set for both TX and RX.
Weird thing is, I hooked the computer up to it to try re-programming it, just to make sure, and when the programming cable is plugged in, not even reading or writing data, it functions as it should. As soon as I disconnect the programming cable, with the mic either connected or not, it reverts back to CSQ.
Just a burned up old radio, or might there be a fix for this?
Delta
kd4efm
Florida
Under options, look for off hook decode
Sent from my SM-G935P using Tapatalk
cmdrwill
So Cali
OK, I checked the box, and now it works.
Thank you for your help. I forgot about that function completely. Delta
It worked because you did not have the mic hang-up button grounded, or something messed up in the mic.
One check we do is measure the DC voltage on the hank-up button, usually about 5 volts ;Off Hook.
kd4efm
Florida
Issue solved, programming.
