TK-981 Discriminator output.
n8lwx
Eaton Rapids
Attempting to resurrect my Private Patch V and use the repeater control feature. I am in need of the discriminator output location. I need to connect
BEFORE de-emphasis. It needs to be BEFORE the capacitor. I have looked at the schematic but these tired old eyes just can't seem to find it.
Any help would be appreciated. Thx
If you have a KCT-19 accessory connection cable, you can pull the receiver detector output off pin 4.
n8lwx
Eaton Rapids
I tried pin 4 and can see "noise" at the controller. Not sure if what comes out of pin 4 is "BEFORE de-emphasis " whatever that means. That type of "de-empasis" is required per the CSI Private patch V manual. I am going to hook the controller up to the old Heathkit HW-24 dual band that it was connected to 25 years years ago and see if it works like it used to. If it works with that radio then I will need to dig deeper into the TK-981 and actually try and find the pin the squelch discriminator begins at. Thanks
Its before de-emphasis. 0.250mv peak to peak.
If you don't have the KCT-19, it's at PIN 1 of CN1 on the TX/RX board. There's also a test point just above that connector.
n8lwx
Eaton Rapids
mmckenna & mass-man Thanks !
Was able to get the CSI private patch/repeater controller fired up after 25 yrs. It's now hooked to the TK-981 . I use one 981 as a transmitter and another 981 as a receiver with 915 toyo filters @ 927.225/902.225 73
