Tk-X180 2 tone question
Colton25
So i've asked before here on RR if you can have more then 4 sets of 2-tone's and the answer I've gotten is no. However i'm trying to figure out what the 4 call formats in each decode tab are for. Obviously right now i have A-B format setup for each decode set giving me only 4 different sets of tones. If i set up a A-B and C-D on the same decode tab wouldn't the radio alert for both sets giving me the option for more then 4 decode sets?
Muhlenberg County, KY
That is correct. There is at basic FOUR 2-tone tabs, with the ability to decode up to 4 tone sets each. All in all allowing up to 16 two tone patterns to be decoded. Now all of this greatly depends on how many patterns you're looking to decode that uses up to 4 tones in all.
Sent from my SAMSUNG-SM-G891A using Tapatalk
Colton25
So let's say in (decode) 1 I have this..
A-B 832.5/600.9
C-D 928.1/600.9
It will alert for either one but I cannot change that from the radio, essentially I can't have the radio alert for one and not the other. Am I understanding this correctly?
A-B 832.5/600.9
C-D 928.1/600.9
That is correct. Whatever you have programmed under 2-Tone x, that is the set(s) of tones that will decode. No way to pick and chose exactly which particular set of tones will decode. So if you have 4 different sets of decode sequences programmed for 2-tone 1, all 4 of those will be monitored for and decoded as recieved on whatever channel you have it assigned to monitor.
