TK2170 Fleetsync ID
Steveradio
LehighValley/Poconos Pa
Im trying to set up our radios to show ID which most of them got figured out. Only problem Im having is letters in the sequence. the ID comes up as 100-1752 which we are using conventional system the first part doesnt really matter.
We have officers such as 17B and thats it.. we could possibly use alternate numbers but just curious if anyone knows how get letter to display on radio?
This is a awesome radio and recomend it for anyone in industry, we have numerous in our fleet and not many complaints except Talkaround from repeaters, They power even at 5watts does not cut the coverage some time. We are looking into a repeater..
Av8tor56
Roswell, NM
You have to use the alias table and set it up to show that 100-1752 is 17B. This will have to be done in every radio that you want to show the alias ID.
alphacommnj
Gillette, NJ
That's correct, you will have to use an alias for each radios ID number. This will display the name ie: TOM or 17B instead of the unit ID ie: 100-1752. Kenwood FleetSync is not capable of having letters in the unit ID, only numbers.
Motorola MDC1200 is capable of having letters A-F or number 0-9 in the 4 unit ID xxxx.
Kenwood FleetSync can only accept numbers 0-9 in its ID xxx-xxxx
