TK290/390 Cps
otobmark
NC
Going through old stuff and found a few of theses. I tried to program them with the cps I had from before. None of the versions I had would run on windows. I sure that at least one worked with windows in the past albeit older version for sure. Anyway I can program these?
KPG-38 needs to run in DOS.
It's been a while, but I think I was able to get it to run under Windows XP.
Other option, download a program called Rufus onto a USB drive and set your older computer to boot up on that. That'll go into pure DOS mode. You can load KPG-38 onto the USB drive and run it off that.
otobmark
NC
Hopefully I find old Lenovo formerly mounted in my vehicle (cracked screen but working at retirement). XP
That's a good option. I have an old one from the early 2000's that I've kept running with windows XP and a lot of older software on it. I don't use it very often, but when I do, its invaluable.
Even if you can't find it, getting old laptops from flea markets or e-Bay is really easy.
There's a pretty good market of used/refreshed Panasonic Toughbooks on eBay if you want to go full beans into it.
wd8chl
I'm using KPG-38DN V2.01 in Win10 no problem. There are still some 290/390's out in the field-not many, but some.
I even use the KPG-22U USB cable to program them.
mrweather
I still maintain an old Thinkpad with a real serial port and running MS-DOS 6.2 for programming my TK-x90 portables. :)
