To anyone looking to acquire commercial radio programming software:
i have tk3140e 440 to 470 mhz, my software is kpg38n(m1), when i programe my radio the screen display ( UNPROGRAM ) then i can;t acess it again... please how can i rsolve it?????????
yes i know that but my radio program is kpg38n(m1) this is my version 5tone v1.05 , i want to upgrade to let me use kpg74d...mybe be i need new firmware!! but i couldn't find it!!
ambdrvr is correct. KPG38D is program software for the TK-290 radio. KPG74D is what is needed to program a TK-3140. I am surprised you could even write to the 3140 with the wrong software, but obviously the codeplug is corrupt. Don't worry about firmware upgrades now. You will need to get the correct FPU and build an archive from scratch (since the radio cannot be read) and dump that into the radio. Disregard the warning "Model type mismatch" and program anyway. That is your only choice.
nooo se attachment i make print screen... that is my version,,, i need to program with kpg74d but my radio basicly not allowed only kpg38n(m1) can do it....i think my firmware,,,
this version not allowed to make simplex channel
this version not allowed 12.5 6.25 space channel only 25
this version make recive range only from 440.000 to 453.975mhz and transmite 454.000 to 469.975mhz
this version only allowed 5tn signal plus qt no qdt allowed.....
Have you tried to read/write the radio with the KPG-74D software? I am just curious if that would fix your problem. I am asuming that since you are in Isreal that you have a foreign version of the radio which probably does take a different software package but it might be worth a shot to try the American version so see if it will work.
According to Kenwood Gloabal, you should have the TK-3140E model radio. That being the case you need the KPG-74DM2 software to program that radio. That is all that I can find on that radio since it is apparently a European model. Hope this helps.
Anyone with access to kenwood online will be able to get you the firmware you need. Alternately you can call kenwood and chat them up. Could someone have tried reading this radio with KPG74?
