TK3173K US Verison Question
Steveradio
LehighValley/Poconos Pa
We purchased few additional radios and the radios we got are all working fine and cloned perfect. The only issue have is after program noticed the knob selector didnt do anything except beep when tun it. I was able to program all other keys to my specs except had keep B - C buttons for up/Down switches. Normally we use C for Inversion on/off.
I must be having a memory loss monet because for life of me cant find the pull down menu for knob selector. Honestly if was only one using radios wouldnt care but when have others than only know how certain buttons operate it makes life difficult. haha. Suggestions help appreciated.
Steveradio
Thanks was in that section for some reason couldnt do anything with "Selector" It highlights everything else and shows picture of unit etc.. but not the selector
SB-Wi
Eastern Dane Co
Is your model set to TK-3173[UHF]:K ? (Model > Product Information)
The selector options are disabled in M, E, & X market codes
Steveradio
Sure its the Model E so that would make sense than.. Appreciated. Wanted make sure wasn't forgetting something. Oh well they can live with the button up/down.. why did they disable the function or what did they replace it with. Meaning why have dam selector than.
SB-Wi
Eastern Dane Co
Are the radios E series or just the software? If it's the radios, flashing with K series firmware might work--ask Kenwood or a dealer. If software, obviously you need a different version (my KPG-101D only has the K series).
A couple of work arounds would be to program 1 channel per zone and use the selector knob or program the B button to change the channel (up or down) and it should cycle after the last channel. You could still use C for inversion.
Steveradio
I got ahold of my local rep and he talked me threw it and yes it was a version issue.. too many KPG101 versions and if don't keep up with things it gets confusing.
Took a break from programing once we switched everything to Narrowband and haven't really had to reprogram anything in awhile.
Appreciate the tips, the only thing notice is once in awhile the radio beeps. Its not being touched just sitting in cup holder. check and no indicator lights are on. sounds like battery low beep but everything is good.
thanks
